- <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:m0="http://tempuri.org/type">
- <SOAP-ENV:Header>
  <Token>{F1D5EAFA-4744-4D82-860F-FE114D42CB74}</Token>
  </SOAP-ENV:Header>
- <SOAP-ENV:Body>
- <m:UpdateValues xmlns:m="http://tempuri.org/message/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
  <sName xsi:type="xsd:string">Domains</sName>
- <vaValues xsi:type="m0:ValueListValues">
- <m0:ValueListValueInfo xsi:type="m0:ValueListValueInfoType">
  <m0:ID xsi:type="xsd:int">1</m0:ID>
  <m0:Text xsi:type="xsd:string">Items</m0:Text>
  </m0:ValueListValueInfo>
  <m0:ID xsi:type="xsd:int">2</m0:ID>
  <m0:Text xsi:type="xsd:string">Portfolios</m0:Text>
  <m0:ID xsi:type="xsd:int">3</m0:ID>
  <m0:Text xsi:type="xsd:string">Gizmos</m0:Text>
  <m0:ID xsi:type="xsd:int">4</m0:ID>
  <m0:Text xsi:type="xsd:string">Wizards</m0:Text>
  <m0:Weight xsi:type="xsd:float">3.14</m0:Weight>
  <m0:ID xsi:type="xsd:int">5</m0:ID>
  <m0:Text xsi:type="xsd:string">SubItems</m0:Text>
  <m0:WeightDouble xsi:type="xsd:double">23.1023456789</m0:WeightDouble>
  <m0:ID xsi:type="xsd:int">6</m0:ID>
  <m0:Text xsi:type="xsd:string">Categories</m0:Text>
   <m0:Weight xsi:type="xsd:float">0</m0:Weight>
  </vaValues>
  </m:UpdateValues>
  </SOAP-ENV:Body>
  </SOAP-ENV:Envelope>
